caliper o ring install - NCRS Discussion Boards
  • Tom R.
    Infrequent User
    • August 31, 2020
    • 13
    Caliper O-Ring.Are new pistons needed?If not how to get piston in caliper?
    Tom Roberts
  • Mel S.
    • August 31, 1992
    • 264
    Re: caliper o ring install
    I changed my 66 over to O-ring about 10 years ago and never had a problem. The kit comes complete with all the items that you need. It is not hard but a little messy. You do NOT have to be a master mechanic to do the change over. At the same time I converted over to DOT 5.
    Mel
    • Tom R.
      Infrequent User
      • August 31, 2020
      • 13
      New pistons ? I just have a rebuild seal kit. I have lip seal pistons. the O ring seals ​will not fit on The lip seal piston, do I need o ring seal pistons ?
      • Tom R.
        Infrequent User
        • August 31, 2020
        • 13
        I guess the question is, are there 2 kinds of caliper pistons.Are pistons the same for lip seals,as opposed to O ring seals?
          • 43246
          Tom------
          Pistons are specific for original lip seal and o-ring so you need the correct pistons for the seal type you are using,
          • Mark S.
            • July 31, 1983
            • 660
            This probably does not help; however, you have the traditional GM type of piston and seal (disc and spring) that most rebuilders use and there is a puck and seal by a company called Precision Engineering.
            • Tom R.
              Infrequent User
              • August 31, 2020
              • 13
              Thank you all.
              Problem solved.
