Going to help a friend tune up his 270 H P. Can someone please answer a few questions below.
Set points each @ 29 degrees dwell, overall should wind up around 34 degrees dwell?
What is best all in timing advance target?
Coil primary & secondary ohms target numbers, 1.5 primary, 8k to 10k secondary?
Proper ohms test of condenser?
A few drops of oil down distributor shaft to lube centrafugal weights?
Any other suggestions appreciated as I want to make sure all is in proper order, and is their an existing NCRS document I can access. I have a ST-12, etc. someplace which I just can't locate right now.
Tks. Doug
Tks. Doug
