steering wheel coating on a c2 - NCRS Discussion Boards
  • Jeffrey S.
    • April 1, 2004
    • 133
    I have a 67 steering wheel that needs to be recoated . I have a can of minwax helmsman spar urethane that I am thinking of using but I don't want to use the wrong thing and make things worse . Anyone have experience with this that can provide some guidance .Thanks in advance Jeff
  • Leif A.
    • August 31, 1997
    • 3645
    Re: steering wheel coating on a c2
    Jeffrey,
    The factory steering wheel for the '67 Corvette is faux walnut (plastic). Don't think you're going to want to urethane that. If there are no cracks in the plastic, I would try some light polishing compound. I've done that before and my wheel looks like new.
    Leif
    • Jeffrey S.
      • April 1, 2004
      • 133
      thanks for the reply / I've scuffed the wheel and sprayed it / we'll see what happens / so far the results are looking good . Jeff
      • Keith B.
        • September 15, 2014
        • 1588
        so you scuffed plastic and spayed it with a wood urethane.
        • Frank E.
          • May 31, 1986
          • 189
          I did the same thing last year. I used a minwax satin and it came out great. The only issue I had was it turned sticky. Using the 3m general purpose adhesive remover and rubbing on it did the trick. Looks great and not tacky at all. Good luck with yor project.
          Frank
          1966 Milano Maroon Roadster
          2004 CE Z06
          • Jeffrey S.
            • April 1, 2004
            • 133
            Yes I did and so far so good . I'd like to know how long it took before the one Frank did got sticky . I sprayed mine at noon and it's now dry and looks much better / a few more coats should do the trick . Jeff
            • Frank E.
              • May 31, 1986
              • 189
              It took about a week before the tackinesses appeared. I live in North Carolina so the humidity may have been a factor.
              Frank
              2004 CE Z06
