Grill Tab - NCRS Discussion Boards
Grill Tab
  • Walter R.
    • January 6, 2009
    • 275
    Grill Tab
    The upper mounting tab on my grill is broken off and I brought to a machine shop to fabricate and weld a new tab. The machinist was concerned about the metal that the grill is made of. Does anyone have any experience with repairing the tabs on the grill itself.
  • Tom E.
    • June 1, 2019
    • 448
    Re: Grill Tab
    The grill is cast metal, I would not attempt to weld it. Can you post a photo of the broken tab? May be able to pin it and reenforce with epoxy.
    • Walter R.
      • January 6, 2009
      • 275
      Re: Grill Tab
      Thanks Tom. The machinist suggested doing that as he didn't think welding was an option. I had told him I would check with the NCRS TD site first to see what insights I could get.
      • Gary B.
        • February 1, 1997
        • 7079
        • Mark F.
          • July 31, 1998
          • 1610
          Re: Grill Tab
          Not every welder knows what pot metal is or how to weld it. We review the proper way to weld pot metal in a safe effective manner with multiple welding machines.
          thx,
          Mark
          • Tom E.
            • June 1, 2019
            • 448
            • Patrick B.
              • August 31, 1985
              • 2017
              Re: Grill Tab
              There is a product called Pot Metal Solder by the Muggy Weld Company that works at a temperature that does not damage pot metal. I used it to fill some corrosion holes in a pot metal console, and I’ll bet it would work very well to reattach a broken grill tab.
              The Muggy Weld also claims it can be used to attach other metal pieces to pot metal, so even if you need to make a new tab from steel or aluminum, it can be attached to the pot metal grill with the pot metal solder.
              • David Z.
                • April 1, 2002
                • 183
                Re: Grill Tab
                Some info here regarding possible "fixes" for the broken tab.
                https://www.corvetteforum.com/forums...ll-repair.html
                Dave Z
                Dave Zuberer
