TI or non - TI ignition - NCRS Discussion Boards
  • Roger M.
    • October 30, 2019
    • 27
    How do I tell if my 1966 Covette with 327 / 350 engine has a TI ignition or not?
  • E S.
    • December 29, 2008
    • 451
    Re: TI or nont TI ignition
    Hi- There are numerus ways- This might be the easiest-A factoIMG_20220313_163044868.jpgry TI ignition would have this component installed.
      • 15706
      Open the distributor cap window and look to see if it has a point set.
      • Roger M.
        • October 30, 2019
        • 27
        much appreciated! it does not have that item.
        • Larry E.
          • 1694
          A quick way is to look for a Ballast Resistor that is left of the Master Cylinder on the firewall. If its there
          then no TI and vise versa. Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Roger M.
            • October 30, 2019
            • 27
            Thank you Larry. It does have one so no TI.
            • Mark F.
              • July 31, 1998
              • 1592
              Post #4 says no points, right? - indicating it is TI
              Post #6 says yes (it does have a ballast resistor), right? - indicating it is not TI
              Did I miss something here?
              thx,
              Mark
              • E S.
                • December 29, 2008
                • 451
                I think post #4 might be the reply to post #2 (picture of amp)
                • Roger M.
                  • October 30, 2019
                  • 27
                  Correct. No amp and a ballast resistor. Sorry for any confusion.
                  • Mark F.
                    • July 31, 1998
                    • 1592
                    Ahhhhhh, Bach (as Radar would say )
                    I thought Post #4 was in response to Post #3...my bad..."never mind" (as Emily Litella would say)
                    thx,
                    Mark
                      • 15706
                      Good catch... glad it got resolved and didn't cause a global thermonuclear war!
