Can I restore my aluminum intake - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1187
    Wondering if anyone on the TDB can give my advice on how to restore my 327/350 intake ?
    Someone started to do a minimum polish of the exposed aluminum surface.
    Ray
    I hope you dance
  • Michael M.
    • January 31, 1993
    • 603
    Re: Can I restore my aluminum intake
    Have the intake manifold vapor blasted.
    • Floyd B.
      • October 31, 2002
      • 1046
      I got good results with jelly aluminum cleaner and a power washer. The power washer I used was an electric 1700psi type - not a gas powered 2500+psi. Other methods would probably work fine. Just don't use any type of abrasives. If you decide to use the jelly, be careful and follow the instructions on the bottle. If left on too long, it will turn the aluminum black.
      "Drive it like you stole it"
      • Kenneth B.
        • August 31, 1984
        • 2084
        Ray
        Really no way to put the foundry sand cast finish back on after its been polished. I have seen some that were RESKINED & its not a sand cast surface.
        • Gary B.
          • January 31, 1997
          • 6986
          Ray,
          Just a warning. There are many techniques and products that will damage the finish of an AL intake. My recommendation is to send it to someone who restores them professionally. I think Jerry MacNeish does them, but there are others. Search thru the archives for recommendations.
          Gary
          • Robert P.
            • October 19, 2019
            • 301
            I will second Gary's advise sent mine to Jerry MacNeish for a small repair and refinish and it came out perfect
            Bob
            • Chris S.
              • December 31, 1999
              • 1064
              I vapor hone blast all my alum - it looks just like the day it was cast
              I also have used Jerry M with great results.
              We focus on the finishing touch on a product such as Vapor Honing, Glass Beading, Sand Blasting. We have many different finishing processes that set us apart. Making parts look better than new. Get the original look and Finish Back! You may be looking into a Vapor Blasting Service for your
              This is a company I use - He does ALOT of work for Kevin at Corvettes Inc
              • Joe R.
                • July 31, 1976
                • 4547
                You might want to check with John DeGregory as he does a fine job on valve covers and is an expert with FI units!
                JR
                • Kenneth B.
                  • August 31, 1984
                  • 2084
                  JR
                  Those are diecast and not sand cast. BIG DIFFERENCE on finish.
                  • Page C.
                    • January 31, 1979
                    • 802
                    I also have had Jerry MacNeish refinish an aluminum intake manifold. Was very pleased.
                    • Gary J.
                      • March 31, 1980
                      • 1229
                      Jerry is also great in making repairs too.
                      • Daniel S.
                        • January 13, 2011
                        • 307
                        We've used Jerry to repair and reskin countless intakes throughout the years. I suggest being patient as the lead time is lengthy, but the service is great.
                        • Ray G.
                          • May 31, 1986
                          • 1187
                          Hello;
                          Thank YOU to all who offered advice on the Aluminum Intake.
                          Ray
                          I hope you dance
                          • Garry M.
                            • June 30, 1997
                            • 49
                            Hey Ray,
                            A number of us had good results with J&P Precision Deburring in CA.
                            There is a Vapor Blasting/Honing place in Mesa. JRA Vapor Honing. It happens to be right around the corner from Streetside Classics, where we'll be for our chapter judging meet this weekend. Only open M-F, 9-4pm. Website is jravaporblasting.com I may pop by there before setting up on Friday.
                            Cheers
                            Garry
                            • Ray G.
                              • May 31, 1986
                              • 1187
                              Thanks Gary
                              I hope you dance
