Curious on spare (1963 tire on 1974 rim) on 1971 LT-1 - NCRS Discussion Boards
  • Mick D.
    • January 22, 2022
    • 159
    Hi Folks,
    Pulled the spare on my 71 LT-1. It isn't date correct but I do have the date correct rim stored in the garage (without a tire).
    This won't be great for judging on my car, so am thinking I'll try find someone who needs a 74 rim, or a 1963 tire.
    I'm assuming the tire is '63 based on the code, but maybe I am wrong.
    What do you think?
    Check out the NCRS Points Tabulator/Calculator Helper
    Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
    1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
    1971 LT-1 : Full date codes inventory
    • 43286
    Re: Curious on spare (1963 tire on 1974 rim) on 1971 LT-1
    Originally posted by Michael Dreeling (68813)
    Hi Folks,
    What do you think?
    Mick[ATTACH=CONFIG]110691[/ATTACH][ATTACH=CONFIG]110692[/ATTACH]
    Mick------
    It's definitely NOT a 1963 tire. For one thing it's a radial tire and radials like this one did not exist in 1963. In addition, the DOT (Department of Transportation) did not exist in 1963. I'd say it's a tire from the 1973-74 period.
    • Gary B.
      • February 1, 1997
      • 7077
      Michael,
      I don’t think that Firestone Wide Oval brand of tire existed in 1963. I think it appeared in 1967, or even later.
      Also, as far as I know the date code system for Firestone tires has not been publicly disclosed.
      Finally, I think the DOT identification on tires didn’t start until 1971.
      Gary
        • 15637
        A federally mandated tire dating system began in calendar year 1971, so if that tire is later than 1971 it should follow that code. That code is available in the TIM&JG which you can get from the NCRS store in one of the links above, but for your edification Google also works for this subject:
        Learn more about The U.S. Department of Transportation (DOT) tire identification number located on the sidewall of each tire. Browse for tires online today
        I can't read your photo well enough to de-code it myself, so I'll leave that to you.
        • Gary B.
          • February 1, 1997
          • 7077
          Terry,
          Can tires codes of any brand now be decoded? I thought only the Goodyear code system was publicly disclosed.
          Gary
            • 15637
            Originally posted by Gary Beaupre (28818)
            Terry,
            Gary
            Any tire manufactured in Calendar year 1971 and newer can be decoded. It is before 1971 that only Goodyear codes are available.
            • Gary B.
              • February 1, 1997
              • 7077
              Thanks Terry.
              Gary
              • Mick D.
                • January 22, 2022
                • 159
                Thanks Joe - I should have done more research, although there is very little on Firestone date codes out there. 73-74 would match the rim. Probably came with this spare when the owner put it in the tub.
                Mick------
                • Mick D.
                  • January 22, 2022
                  • 159
                  Also curious. I have the TIMJG for my 71 and there are only Goodyear tables in there. It has explicit call outs that Firestone isn't available and shouldn't be judged. Maybe it is different in other manuals for other years.
                  Terry,
                  Gary
                  • Patrick B.
                    • August 31, 1985
                    • 2015
                      • 15637
                      Michael
                      See date code system 4. In the 1970-72 TIM&JG, Edition 6, Page 101.
                      If you have the 5th Edition the same information is on Page 102
                      • Mick D.
                        • January 22, 2022
                        • 159
                        Thanks Terry, I understand you now, thanks for clarifying.
                        Michael
                        • Mick D.
                          • January 22, 2022
                          • 159
                          I think you are right Patrick.
                          Originally posted by Patrick Boyd (9110)
                          In the photo, the date code looks like 163 which would be the 16th week of 1973 since I don’t think Firestone Wide Ovals were made in 1983.
