Oil Pan Bolts - NCRS Discussion Boards
Oil Pan Bolts
  • Walter R.
    • January 6, 2009
    • 275
    Oil Pan Bolts
    The Tech Manual states the front and back two oil pan bolts on a BB are 1/2 inch. do they have a wire washer like the other bolts which are 7/16 or do they have a split washer?
    • 43287
    Re: Oil Pan Bolts
    Walter------
    The corner bolts are 5/16-18 with a 1/2" wrench size. These bolts have a captured split lockwasher.
    • Walter R.
      • January 6, 2009
      • 275
      Re: Oil Pan Bolts
      I wanted to make sure. I ordered a set of bolts from a supplier and they were all 7/16. Typically, the parts suppliers are pretty accurate with the bolt size and markings. I ordered the set as I was missing the corner bolts but had all of the correct 7/16 bolts. Any idea how I could acquire these bolts?
      • Leif A.
        • August 31, 1997
        • 3654
        Re: Oil Pan Bolts
        Walter,
        The SB has the larger bolts on the four corners but I don't believe the BB does...BB bolt sizes are all the same. The BB, also, has reinforcements for the four corners. See below.
        From Zip:
        Purchase 1966-1967 Corvette Radiator Shroud Mount Bolts at Zip Products - complete source for C2 Corvette radiator fan shrouds & mounting hardware. (GM Part 122007, 120228)
        1965-1974 Corvette 396/427/454 Oil Pan Bolt Reinforcements at Zip, the source for C2 & C3 Corvette oil system components including dipsticks, filters, pumps & oil pan.
        From Paragon:
        https://www.paragoncorvette.com/p-35...lt-kit-bb.aspx
        Leif
        • Michael V.
          • May 31, 1995
          • 77
          Re: Oil Pan Bolts
          Call rich Pasqualone at 610 462 4441 in New Jersey if you want original ones. He is the best.
          • Gary B.
            • February 1, 1997
            • 7077
            Re: Oil Pan Bolts
            All
            The ‘66 JG is pretty clear when describing the oil pan bolts. At the start of the oil pan section, the JG describes things common to all oil pans, small block and big block. It says “The pan is attached to the block with 7/16” indented hex head bolts with captured serrated washers; except for the bolts passing through the corner reinforcements, which are 1/2” indented head size.” Then, in the the section specific to BB, the JG reads “The same recessed 7/16” hex head bolts secure the pan to the block along the sides and 1/2” hex head bolts secure the front of the oil pan to the left and right of the timing cover and at the left and right rear.” Since SB and BB use a different number of bolts for the oil pan, the repro parts companies sell a separate kit for each. If you look at the old Long Island Corvette website and zoom in on the oil pan bolt kit contents you can see the bolts with the larger head size in each of the two kits, that are intended for the corner locations. So, the LIC kits were consistent with the JG.
            in Leif’s first photo, I think the L headmark bolts at around the 5 o’clock position have a larger head size than the nearby E headmark bolts.
            Gary
            • Ray K.
              • July 31, 1985
              • 375
              Re: Oil Pan Bolts
              Walter,
              All big blocks use the same bolt size, as described by Joe, 5/16" X 18 thread with 1/2" wrench size for attachment of the oil pan to the block.
              At the front corners of the oil pan, they use 1/4" X 20 bolt with a 7/16" wrench size ( 2 required ) for attachment to the front timing cover.
              Ray
              • Gary B.
                • February 1, 1997
                • 7077
                • Gary B.
                  • February 1, 1997
                  • 7077
                  Re: Oil Pan Bolts
                  After looking at the LIC kit photo, I see the mistake I made. Here’s a photo of the LIC BB kit.
                  The E headmark bolts with a split lock washer must be the corner bolts. The L headmark bolts with the star washer must be the side bolts. There are many more bolts with the star washer in the photo, so those must be the side bolts. The L headmark side bolts look like they have the larger (1/2”) wrench size and the E headmark corner bolts look like they have the smaller (7/16”) wrench size. If so, that is the opposite of what the JG says.
                  Gary
                  • Ray K.
                    • July 31, 1985
                    • 375
                    Re: Oil Pan Bolts
                    Gary,
                    I looked at my '65 JG ( 6th edition ) and I believe it is incorrect as well as to the bolt sizes. Most likely offers correct info on the head style and identification. I have a 427 on an engine stand and it does not have original bolts with the recessed heads, but I can assure you about the thread and wrench size being correct.
                    Ray
                    • Leif A.
                      • August 31, 1997
                      • 3654
                      Re: Oil Pan Bolts
                      Originally posted by Gary Beaupre (28818)
                      Ray,
                      Wow! Your description is remarkably different from what the ‘66 JG says. And your description seems to exactly match what is contained in the Paragon BB kit based on Leif’s photo. Seems like a correction to the JG is needed.
                      Gary
                      If you look closely at the Zip photo, the bolts for the water pump cover are mixed in with the rest of the oil pan bolts...kind of in the center of all the bolts.
                      Leif
                      • Gary B.
                        • February 1, 1997
                        • 7077
                        Re: Oil Pan Bolts
                        Originally posted by Ray Kimminau (8917)
                        Gary,
                        Ray
                        • Gary B.
                          • February 1, 1997
                          • 7077
                          • Leif A.
                            • August 31, 1997
                            • 3654
                            Re: Oil Pan Bolts
                            Here ya go...
                            Leif
                            • Gary B.
                              • February 1, 1997
                              • 7077
                              Re: Oil Pan Bolts
                              Thanks Leif.
                              So, three out of three JGs incorrectly say on a BB that the front corner bolt heads are the larger size? Have I got that right?
                              Gary
