The support tabs on the upper and lower front fiberglass valance have broken off on my 1966. Additionally the upper tab on the grill is broken off. I need to form new support tabs on the valance and fabricate and weld a new tab to the grill. Could someone please send a picture of their grill/valance in that area so I have a visual to form new support tabs as accurately as possible.
Grill and Valance middle supports
Re: Grill and Valance middle supports
Walter Here are a few which may help.
The loose part is a cutoff tab from a 63+ GM surround I used as a guide on a '67 broken tab. I used a mixture of chopped mat and resin.
Here's a '66-67 grille. Not a good close-up of the tabs but you may be better off fabricating some sheet steel and riveting to what's left.
P8250007.jpg- Top
Research the brackets that attach to the grill. We see repairs done on the judging field and most are not typical production and subject to a deduction.Mike Doty
Intermountain Chapter Judging Chairman
Region VIII Director- Top
Mike, Yes I understand. I was thinking functionality. Welding those pot metal pieces can be a problem.
Rich- Top
