1966 Front Power Brake Brass Block - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1068
    Converting a 66 from manual to power brakes and need to change the front brass block that is on the frame. I bought a reproduction one but it won't even bolt to the frame as the hole spacing on the bracket is wrong. So the question is now - where can I find the "correct" block. I've checked all of the typical vendors web sites and they all seem to have the same one I bought.
    Tom
    2007 Z06, Lemans Blue
  • Tom B.
    • March 1, 2002
    • 140
    Re: 1966 Front Power Brake Brass Block
    Call David Sakolowski he has many used original parts he advertises in the Driveline.
    • Larry M.
      • January 1, 1992
      • 2701
      I would call Inline Tube and see if they have what you need. You might email them a picture to illustrate the issue, or provide a dimension of tab to hole centerline for what you need.
      You could also modify (extend) the tab on the reproduction with a small amount of effort and a welder.
      Larry
      • Thomas H.
        • August 31, 2005
        • 1068
        Good point - I'll give him a call.
        • Thomas H.
          • August 31, 2005
          • 1068
          Inline tube doesn't have it.
          I fought with incorrect reproduction parts when I did my 58 - drove me crazy that the manufacturers would get it 90% right........ Now that I'm doing this 66 I'm starting to have reproduction flashbacks.......
          Tom
          • Larry M.
            • January 1, 1992
            • 2701
            How about this. https://shop.docrebuild.com/1965-196...GM3878804.aspx
            Larry
            • Bill B.
              • January 1, 1997
              • 40
              The bolt that holds it has a captive washer, could you file out one side of the hole until the bolt lines up? It appears the bolt would still cover up the enlarged hole?
              • Thomas H.
                • August 31, 2005
                • 1068
                Hi Bill,
                Yes I could but I shouldn't have to. The part should have been made correctly in the first place. I think I found one at one of the typical vendors - at least it looks like it has the right spacing from the picture on line. Should be here tomorrow. If it's correct, I'll post some pics along with the vendor.
                Tom
                • Thomas H.
                  • August 31, 2005
                  • 1068
                  New part came in yesterday. While it is not "exact", it does fit. This part came from Zip.
                  Couple pics of the three parts.
                  Tom
