Any secrets for A.I.R. tube removal? - NCRS Discussion Boards
  • Mathew S.
    • July 9, 2015
    • 137
    Working on getting some old smog tubes out of the exhaust manifolds, while still on the car. I had no issues removing all but cylinder 5,7, and 8. Currently they are getting sprayed with penetrating oil (CRC Knock er lose). Not concerned with saving the tubes since they are cracked and rusted out, but would like to avoid pulling the manifolds.
  • Sal C.
    • December 1, 1984
    • 430
    Re: Any secrets for A.I.R. tube removal?
    No substitute for heat.
    • Jeffrey S.
      • May 31, 1988
      • 1899
      Also, if you don't want to save the tubes, cut them off close to the nut so you can put a good socket on it. It's a lot better than an open end wrench or even a good line wrench.
      Jeff
        • 43277
        Jeff
        Jeff------
        Yes, definitely. And, using an impact socket with a high torque impact tool might be enough by itself.
        • Peter M.
          • May 30, 2013
          • 361
          Mathew,
          Are you trying to get the tube assemblies off or get the extension tubes out of the manifold?
          • David H.
            • June 30, 2001
            • 1559
            Originally posted by Peter Miller (58508)
            Mathew,
            Mathew
            If issue is getting extension tubes out... I made a simple tool from stiff coat hanger wire. Put a hook at wire's end, and trim so that hook end just goes in tube. Grab (hook) inside edge of tube with tool and extract.
            Dave
              • 43277
              Originally posted by David Houlihan (36425)
              Mathew
              Dave
              Dave——-
              The extension tubes often have considerable encrustation with combustion products on the external surface of the tube. When this occurs they cannot be removed by the method you mention. In that case, they have to be driven out from the inner end with the encrustation sheared off as the tube is driven through the manifold.
              • David H.
                • June 30, 2001
                • 1559
                Dave——-
                Joe
                Sounds like a PITA. I guess just lucky for me, "hook and tug" and out they came!
                Looks like, some "dis-assembly" required.
                Dave
