help with fastner identification - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8408
    is part #273446 a pan head phillips sheet metal screw or a hex head, or slotted? bet ole dave bartush knows the answer. i dont. mike mccagh
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: help with fastner identification
    Mike,
    Per 19578 P&A Group 8.970-8.977 part #273445
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Mike M.
      • May 31, 1974
      • 8408
      gary: what's the significance of "Cr"? thanks, mike
      • Harry S.
        • July 31, 2002
        • 5344
        Is this it?
        • Gary C.
          Administrator
          • October 1, 1982
          • 17940
          abbreviations from the P&A
          NCRS Texas Chapter
          • Mark F.
            • July 31, 1998
            • 1598
            Hi Mike,
            Could it mean "Cross Recessed" as indicated in this link?
            thx,
            Mark
            • Mike M.
              • May 31, 1974
              • 8408
              thanks to all . mike
              • Rod K.
                • 445
                Believe that would be it, note the thread cutting (slot) tip.
                • Gary B.
                  • February 1, 1997
                  • 7069
                  Here are some sketches of the different point styles for self-tapping screws.
                  • David B.
                    • March 1, 1980
                    • 690
                    You got your answer Mike, if you really want to be specific it is a type BT as indicated in above chart #25 and Harry's bag.
                    • Gary B.
                      • February 1, 1997
                      • 7069
                      David,
                      Do you know the difference between point style 25 vs 23? Coarse vs fine pitch?
                      Gary
                      • David B.
                        • March 1, 1980
                        • 690
                        Was wondering about that also -- A QUICK study shows the Type designated is for the particular material (alum., sheet metal, plastic etc.) and the hole size recommended for that particular application. Grouped as follows:
                        Type A
                        Types AB, B, and BP
                        Types BF, BT and C
                        Types D, F, G, and T
                        • Mike M.
                          • May 31, 1974
                          • 8408
                          you got it gary. type 23 cut fine threads in the al, zinc other soft metals and plastics.
                          type 25 are coarse thread cutters. agin, thanks to all who enlightened my sorry ass. mike
