68 Radiator support Grommet - NCRS Discussion Boards
  • Jeff P.
    • 799
    AD353F5F-4075-4254-BCA4-B1F76E62B7F5.jpeg50DB9EA4-F341-40F2-BC56-ECF6BE021108.jpg6F9ED1D0-DA35-466B-9C3E-6AAFBE0FC4AE.jpgMorning , on a 68 radiator support on the right side there is an oval opening for ac hose with a rubber grommet with two tabs. The part number is 3929002. I might have found a company that can reproduce it. I have read some threads of this here. Does anyone have the dimensions of this ? Thanks in advance. Jeff.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 43247
    Re: 68 Radiator support Grommet
    Originally posted by Jeff Pollard (15573)
    [ATTACH=CONFIG]110227[/ATTACH][ATTACH=CONFIG]110225[/ATTACH][ATTACH=CONFIG]110226[/ATTACH]Morning , on a 68 radiator support on the right side there is an oval opening for ac hose with a rubber grommet with two tabs. The part number is 3929002. I might have found a company that can reproduce it. I have read some threads of this here. Does anyone have the dimensions of this ? Thanks in advance. Jeff.
    Jeff------
    Have you checked with Dr. Rebuild? He's the "king of grommets" (and many other things).
    By the way, the GM #3929002 was discontinued without supersession by GM in June, 1974. So, NOS will be, to say the least, difficult to find.
    • Jeff P.
      • 799
      Thanks for reaching out Joe. He was the first one I looked into. Five pages of grommets and nothing close.
      • Brad Hillhouse (37766)
        Jeff -
        Here is pics of front and back side on one of my 68 C60 cars. I believe the part should have three metal bendable tabs that hold it in place on the core support. I know I have another loose one somewhere to get you accurate dimensions.
        Hope these pics help
        Brad Hillhouse
        • Jeff P.
          • 799
            I have two more 68s that need reassembled. Saw your post on CF, maybe that turns up a lead.
            join my facebook group: 1968 Corvette Owners Group
            brad
