carb - NCRS Discussion Boards
carb
  • Wayne W.
    Infrequent User
    • December 1, 1981
    • 9
    carb
    Don't get on here very often in the last 45 years. I have a 63 327/340 and would like to replace the crappy carter carb. Any suggestions would be very helpful. member 5054
  • Kent S.
    • February 1, 1993
    • 205
    Re: carb
    If you're not concerned with NCRS Judging the Edelbrock carb is pretty bullet-proof right out of the box. You will not be able to use your correct aircleaner due to slightly larger airhorn diameter on the Edelbrock. Have you also considered having your Carter rebuilt by a reputable vendor? Many on here have their favorites so you can review their recommendations when they post them.
    • Jim L.
      • September 30, 1979
      • 1816
      Re: carb
      I'd have the AFB rebuilt and not even think about replacing it. My '63 327/300 has pretty much the same carburetor and it's a jewel.
      • Mike M.
        • May 31, 1974
        • 8399
        Re: carb
        I've had nothing but trouble with eldebrock carbs on some of our street rods(we called them street rods when I was still suckin hind teat). anyway, the AFB's are my favorites, the WCFB's 2nd, Holleys 3rd and quadrates forth. of course, nothing beats a 57-65 Rochester. mike
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 885
          Re: carb
          I wouldn't call a Carter Carb crappy. It's one of the easiest to maintain & adjust. Find yourself a good rebuilder and you will be happy with it for another 50 years.
            • 15706
            Re: carb
            The AFB is a very reliable carb. It doesn't have "wet" gaskets like Holleys, so you'll never have fuel bowl gasket leaks.
            The biggest problem is the hot air choke system that gets dirty and clogged up, resulting in poor cold starting because the choke won't set. This is usually easy to fix by cleaning the choke vacuum break piston and bore. You don't even have to remove the carb, just the choke housing, but remember there is a small O-ring that seals a small vacuum passage that continuously draws air from the air cleaner through the heat stove in the manifold to the themostatic spring.
            The heat stove tube inside the exhaust manifold can rust through, allowing exhaust gas into the choke housing that will quickly freeze up the vacuum break piston.
            Use a quality paper filter element like a NAPA 2070. Only use an oil wetted foam element for judging
            45 year old carburetors like 45 year old people can develop problems that require some help. The carb is easy to overhaul, but if you're not comfortable doing it yourself there are several pros who can do everything from a simple "zip kit" overhaul to a full mechanical and cosmetic restoration to look and perform as new.
            • Wayne W.
              Infrequent User
              • December 1, 1981
              • 9
              Re: carb
              Thanks for all the advice, guess my next quest is to find a reliable pro to rebuild, any help would be appreciated. thanks
              • Mike M.
                • May 31, 1974
                • 8399
                Re: carb
                bob kunz in st louis area. PM me for his contact info if u can't find him on google. good luck, mike
                • Wayne W.
                  Infrequent User
                  • December 1, 1981
                  • 9
                  Re: carb
                  OK thanks Mike, I am vacationing in AZ but will pull carb when I get home in April.
                  • Wayne W.
                    Infrequent User
                    • December 1, 1981
                    • 9
                    Re: carb
                    Hi Mike if you could send me the contact info, that would be helpful. thanks
                    • John D.
                      • December 1, 1979
                      • 5507
                      Re: carb
                      Bob Kunz of St. Louis MO. 314-845-2566
                      • Joe R.
                        • July 31, 1976
                        • 4551
                        Re: carb
                        Bob Kunz is the man to rebuild your carb! Use that number Mr. FI gave you!
                        JR
                        • Harry S.
                          • July 31, 2002
                          • 5330
                          Re: carb
                          Contact:
                          Chris's Carb Shop:
                          Address: 7718 N Main St #2550, Dayton, OH 45415
                          Phone: (937) 890-0970
                          Great work on the AFB's and WCFB's I've sent him.
                          • Wayne W.
                            Infrequent User
                            • December 1, 1981
                            • 9
                            Re: carb
                            Thankyou guys, I will contact him when I return home.
                            • Kent S.
                              • February 1, 1993
                              • 205
                              Re: carb
                              Bob has done two AFB's and two WCFB's for me - all have been perfect. He runs the carbs on a test engine before shipping so you can be assured it's a bolt on and go.
