M21 Gearbox in 67 Corvette - NCRS Discussion Boards
  • Colin M.
    Infrequent User
    • May 31, 1984
    • 29
    I have recently received a rebuild kit for the above style gearbox. I have some leftover parts from when I purchased the car in 1986. The syncro Rings are GM part 357234.
    The new rings in the rebuild kit have some differences
    The GM ones are all brass looking the replacements have a metalic look on the tooth surface.
    The replacement rings have two 1/8 inch shallow groves in the inside of the cone evenly spaced between the three major cutouts.
    Which type should I use in the rebuild.
    I hope not to need to go in here again
    Thank you all
    • 43277
