1963 Flywheel - NCRS Discussion Boards
1963 Flywheel
  • Jerry C.
    • November 1, 1995
    • 741
    1963 Flywheel
    I think the flywheel is part number 021 but what tooth count does the starter ring have. I think 168 but could 158. Anyone know? Thanks in advance.
    • 6950
    • Todd L.
      • November 25, 2020
      • 295
      Re: 1963 Flywheel
      Hey Jerry,
      The part # is 3781021 and it is 153 tooth.
      Todd
      • Gary B.
        • February 1, 1997
        • 7054
        Re: 1963 Flywheel
        Todd,
        The casting # is 3791021 (not 3781021), and the GM part number is 3791022.
        Gary
        PS - When searching for one, on eBay for example, it’s good to search separately for both the part number and the casting number, since many people only mention the casting number.
        • Todd L.
          • November 25, 2020
          • 295
          Re: 1963 Flywheel
          You're right Gary, that was a typing mistake on my part, 3791021
          • Tom P.
            • April 1, 1980
            • 1815
            Re: 1963 Flywheel
            Jerry, my 63 flywheel (10.5) has a date. Also I believe if you have a bigger flywheel (11”) the 421 bell housing will not work? Maybe someone can confirm this.
            There is no such thing as a Chevrolet 10.5in flywheel.
            There are ONLY 12 3/4in with 153 teeth, or, 14in with 168 teeth.
            The 153 teeth flywheels use a 10.5in clutch.
            The EARLY (55-62) 168 teeth flywheels had a 10in clutch (replacements are now 10.5in). The 66-later 168 teeth flywheels use an 11in clutch.
              • 6950
              Re: 1963 Flywheel
              Tom you are correct, I should have said 10.5 clutch disc. That’s what I meant.
                • 43258
                Re: 1963 Flywheel
                All Corvettes (and most other GM cars) from 1953 to 2019 used either a 153 tooth or 168 tooth flywheel or flexplate. Here's the breakdown:
                1953-62 all---------------------------------168 tooth
                1963-68 small block-----------------------153 tooth
                1965 L-78----------------------------------153 tooth
                1966-74 big block except L-88/ZL-1-----168 tooth
                1967-69 L-88/ZL-1 with 4 speed---------153 tooth
                1969 L-88/ZL-1 with THM-----------------168 tooth
                1969-82 small block except ZR-1--------168 tooth
                1970-72 ZR-1-----------------------------153 tooth
                1984-96 all--------------------------------153 tooth
                1997-2019 all-----------------------------168 tooth
                • Philip A.
                  • September 18, 2021
                  • 94
                  Re: 1963 Flywheel
                  Heres a good question for ya's. How much did the cast iron flywheel from the factory for the 66-74 BB except L88 weigh? Anyone?
                    • 43258
                    Re: 1963 Flywheel
                    • Philip A.
                      • 94
                      Re: 1963 Flywheel
                      Thanks Joe. Please dont take offense...How sure are you of the weight? Reason I ask is I weighed mine on a scale and it weighed 27lbs. So I don't know if someone thru the years replaced it with another or what. I know the weight can make a huge difference in how the engine revs and launching the car and thru the gears so I want to make sure the weight is correct and what GM put on the 427 400 hp.
                      I am replacing the one I took off with a steel one from Ram Clutches. They have a few with different weights for diff applications.
                      when asking the technical rep, he states the closest they have to the stock weight is their 33lb when they also have a 25lb so now I'm needing proof of factory weight. Do you have such a document or manual that states that?
                      TIA!
                        • 43258
                        Re: 1963 Flywheel
                        TIA!
                        Phillip-------
                        I actually weighed one on an accurate, beam type scale. However, I'll double check it when I get home from this trip.
                        Was there a GM casting number on the back of the one you weighed and, if so, what was it?
                        • Philip A.
                          • 94
                          Re: 1963 Flywheel
                          Yes, 3973456N. I weighed mine on a beam type as well. Thanks Joe.
                          • Gary B.
                            • February 1, 1997
                            • 7054
                            Re: 1963 Flywheel
                            EBay item #: 392226955585
                            Gary
                              • 43258
                              Re: 1963 Flywheel
                              Phillip-------
                              I'll be home Saturday and I can re-check it. Actually, it felt like it did weigh more than 22 pounds but that's what I thought I read off the scale. I'll confirm, though.
