'78 Fuel Gauge & low fuel light not working - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    Ran car a couple months ago and gauge was reading almost empty and low fuel light was on. Started it a couple days ago and gauge was bottomed out on empty and light was not lit. Added 3 gallons and still on empty with no light.
    Have 30 ohms between sender wire and ground wire. I assume this indicates a gauge issue, probably the greater of two evils. Appreciate any input.
    Charlie
  • David H.
    • June 30, 2001
    • 1529
    Re: '78 Fuel Gauge & low fuel light not working
    Charlie
    If you step on your brake pedal does the gas gauge move?
    If so, check for a poor ground connection shared with rear tail lights.
    Dave
    • Charlie P.
      • July 31, 2003
      • 260
      Dave-
      I was doing a test with different resistors to determine if gauge or sender and it started working. So don't really know what happened, but I'll take it.
      Charlie
