Installing exhaust hanger at center crossmember- how to and what to expect - NCRS Discussion Boards
  • Garry B.
    • January 1, 1991
    • 667
    I will be installing a new under car exhaust system and will need to reinstall the center crossmember hanger. What is the best way to approach this? Should it be installed before or after the pipes are in but before everything is adjusted? When the two bolts are removed at the transmission tail section bracket, will there enough room to finesse it in there and will I have to jack up the tail section/ drive shaft to get it in there? Seems like it would be easier to do this first. Thanks.
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
  • Alan D.
    • January 1, 2005
    • 2054
    Re: Installing exhaust hanger at center crossmember- how to and what to expect
    For what year?
    • Garry B.
      • January 1, 1991
      • 667
      Sorry. '67 327/300 automatic
      Garry Barnes #18531
      • Alan D.
        • January 1, 2005
        • 2054
        Surprised nobody helping yet, so here is some information to star with;
        Check the standard "Exhaust System" which uses 3853723, in section 8.
        Then see the items listed for the auto trans M35 option.
        You should find that the same 3852723 is being used. So I would assume that, that bracket is being used for
        64-67 production cars. (warning - I recall an auto car used a spacer in that location when equipped with side exhaust)
        I do not have any photo's of that area for an auto trans.
        • Garry B.
          • January 1, 1991
          • 667
          Alan, thanks for the reply. Yes, I was surprised that the good guys in the white hats hadn't ridden in yet. Maybe later.
          I believe I know what exhaust hanger to use (same for auto and manual 2") but I am wondering if I am going to have to find a way to jack up the transmission tail section in order to slip this hanger into place. Is there anything under there that needs to be supported while I do this? I am hoping someone has done this and they will share their experience with me.
          Garry Barnes #18531
          • Alan D.
            • January 1, 2005
            • 2054
            That hanger, 3852723, is sandwiched in the rear trans mount, so yes I would support the rear of trans.
            Also think the 2" and 2 1/2" use the same hanger. Note; you should find a spacer there already if the conversion to
            outside exhaust was done correctly or if original.
            • Garry B.
              • January 1, 1991
              • 667
              Alan, there is actually a 2" hanger as well as a 2 1/2" hanger. The diameter of the lip that the clamp goes over is specific to 2" as it is on the 2 1/2". Thanks for your thoughts.
              Garry Barnes #18531
              • Tom B.
                • March 1, 2002
                • 140
                If i remember correctly you have to jack up the trans and i would do it from the main case assembly and use a wood block and pull the bracket and mount out together.
                • Chris H.
                  • April 1, 2000
                  • 837
