1968 trim panel bracket. - NCRS Discussion Boards
  • John M.
    • September 30, 2000
    • 43
    For a 1968,is bracket,trim panel lower RH 3930346 available anywhere new or used,I can't find one.
    Thank you John
    • 43273
    Re: 1968 trim panel bracket.
    Thank you John
    John-----
    All I can tell you is that the GM #3930346 was discontinued without supersession in January, 1976. 46 years is a long time for any available inventory to dry up. Seeking a used example is probably your best bet.
    • John M.
      • 43
      Thank you Joe,a used one will be fine ,it will match the one on the left side,I will keep looking.
      John
