Copy/pasted from https://www.forums.ncrs.org/showthre...hat-the-hell-)
My '67 427/390 shows very erratic timing starting at 3800 rpm. I've gone through the entire ignition system and replaced the maintenance items with quality parts, and rebuilt the distributor (which showed no slop in the bearings or end-play). Joe's last comment above made my heart stop a bit...
When checking timing, the balancer line is pretty stable with only minor degree or so fluctuations every now and then when increasing engine revs all the way to 3800. Once it hits this threshold the mark begins swinging wildly off the timing tab in both directions. Does this sound like a timing sprocket and chain issue? Engine is completely original and never been out of the car. 65k miles and owned for 43 years.
I was looking at the Cloyes chain sets, and heeding Duke's comment about the 0.200" rollers, found #C3024 @$45; Duke, is this the one you are referring to? Joe's comment about #9-3110 shows 0.250" rollers @$170(!) so I'd much rather save the $125 if the 3024 will work fine with no issues.
Thanks all!
Owen
Thanks all!
Owen
