Rear Wheels locked and can't select Reverse gear - NCRS Discussion Boards
  • Grahame M.
    • November 7, 2011
    • 225
    Hi all,
    I've been working on my car for some time now but i'm getting closer to getting it back on the ground. A little while ago i replaced the rear gearbox mount and since then (i think) i can't turn the rear wheels (locked) or select rev gear.
    I'm hoping someone on this forum has experienced this and has a remedy. I've obviously put something back in the wrong place. I've attached a couple of picks of the location of the selectors. The car isn't running yet and still on stands but i can select all 4 forward gears.
    Cheers
    Grahame
    69 427 Tri-Power 4 Speed
    Black on Black
    • 6948
    Re: Rear Wheels locked and can't select Reverse gear
    Grahame, is the the reverse lock out working correctly? The rod protrudes down on the bottom of shifter to stop it from going into reverse while driving in forward gears. Another thing you can do is just remove the shifter knob and remove the rod and lever and see if you can select reverse. Also note that some times rotating the rear wheels may help with selecting reverse, reverse is not synchronized if the two gears are clashing with each other you be able to select reverse. Hope this helps,Ed
    • James G.
      • August 22, 2018
      • 800
      IF the rear wheels are off the ground the half shafts may be in a bind.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Alan D.
        • January 1, 2005
        • 2046
        & Maybe in two gears, remove linkage and position in neutral position.
        • Harry S.
          • July 31, 2002
          • 5330
          I agree with Alan, I caused this problem on my car as a nut loosened on the linkage. Had to crawl under the car, reset everything to neutral and tighten it up.
          • Domenic T.
            • January 29, 2010
            • 2452
            I agree with above, sounds like it's in reverse and a forward gear. I intencially do that when installing a 4 speed. and have had nasty calls when some installed and moved the reverse lever while installing. One broke the case at the reverse idler when he popped the clutch.
            Dom
            • Grahame M.
              • November 7, 2011
              • 225
              Thanks everyone for your quick responses.
              I had a look yesterday and all linkages seem to be free as well as shifter. I have stands under chassis and shock mount (so everything didn't hang against new rubbers) so it might have caused this problem.
              Edward, I'll check that tonight. I could pull lockout up against spring and could move to the left but would go into Reverse. I'll also remove the take tailshaft from diff end to see if wheels turn, that should tell me where the problem is.
              If it is in reverse how do I get it out? I have tried moving the Rev selector (with the others in neutral) to no avail. Will I have to loosen everything around rear mount, brackets and crossmembers to allow me to move out of reverse, if Edward's recommendations don't work?
              Cheers
              Grahame
              Black on Black
              • Domenic T.
                • January 29, 2010
                • 2452
                Grahame,
                Reverse should move unless it is not in slot in back plate.
                Dom
                • Grahame M.
                  • November 7, 2011
                  • 225
                  Thanks Dom,
                  Is the back plate part of everything around the shift mechanism I would have loosened or taken out when changing the rear G/Box mount? The car was in neutral when I did the work.
                  Cheers
                  Grahame
                  Black on Black
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Originally posted by Domenic Tallarita (51287)
                    Grahame,
                    Dom
                    Actually, I meant the rear housing, The fork that moves reverse gear is hard to stab. When correct it will allow you to move reverse lever back and forth. There is a pin that has to be removed behind the shifting lever, then you pull the linkage arm out to get the fork in place. That's if I understand what your dealing with.
                    We used to do this to bad guys when they were in the movies. We would lay on the ground and moved the reverse lever. and he was doomed. Now, I only showed how that was done and couldn't do it to any one, but usually the bad guy had someones girl friend at the movies and the boyfriend was real mad.
                    Dom
                    • Grahame M.
                      • November 7, 2011
                      • 225
                      Thanks Dom,
                      I'll have a look at this later today.
                      Cheers
                      Grahame
                      Black on Black
