Powerglide problem - NCRS Discussion Boards
Powerglide problem
  • Vincent B.
    Infrequent User
    • September 20, 2021
    • 10
    Powerglide problem
    i brought my '54 in for some engine work. my mechanic removed the engine, did the necessary repairs and put the engine back in. now i have no reverse. it worked fine before the engine removal. forward gears work fine. he even put it up on the lift, disconnected the linkage and shifted it by hand...nothing. any thoughts ?
  • Tony R.
    • April 19, 2017
    • 201
    Re: Powerglide problem
    But it does have forward gears?
    • Chris S.
      • January 1, 2000
      • 1068
      Fluid level ok ?
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Vincent B.
        Infrequent User
        • 10
        tony, yes, forward gears work fine. we didn't remove trans for engine repairs. re-installed engine and now no reverse...worked fine before
        • Vincent B.
          Infrequent User
          • 10
          fluid level good
          • Vincent B.
            Infrequent User
            • 10
            if it does have to be rebuilt, what would a reasonable price be ?
            • Chris S.
              • January 1, 2000
              • 1068
              is the fluid red and clean ? not burnt
              I rebuild mine for 1200 to 1600
              • Domenic T.
                • January 29, 2010
                • 2452
                If I remember right when I worked for Chevy dealership, reverse was dependent of correct fluid. Especially if torque converter was low. Maybe try over filling it if the converter did not take enough. I seem to remember that reverse would not work with low fluid.
                Good advice from other posts.
                Dom
                • David M.
                  • September 30, 2004
                  • 533
                  Verify the linkage and shifter are adjusted correctly and actually shifting the trans into reverse. I'm no early glide guy but an auto is an auto.
                  The quickest way to trouble shoot an automatic is:
                  1. Verify fluid condition/level. Fluid should be changed periodically just do to age.
                  2. Verify shift linkage movement. Disconnect the linkage at the trans and shift it into reverse. Can you feel the detent? Now try it with the wheels off the ground engine running. Does it move the wheels?
                  3. Read the line pressures. Im not sure where and if a glide has pressure ports but it should?
                  An automatic is nothing more than a hydraulic pump. If the line circuit pressure(s) are incorrect it will not operate properly.
                  Have you had a conversation with the guy who did the engine installation?
                  Did he test run the car after the repair?
