For judging purposes only- original T3 bulbs, GM Restoration Parts....or other?
T3's- best way to go?
Re: T3's- best way to go?
Now operations, C2, there are 25 points for bulbs. There are 6 functions on the 4 bulbs. 25//6 = 4 points per failure.
It's your call. I've seen original T3 test OK prior to operations, they blow during operations. I used original T3 during my operations. One bulb blew when I was turning them off.
- Top
i've had similar experience with originals as harry describes. lately i've been applying a thin film of silicone caulking around the back of the buld where they can suck air and then blow within seconds if they do suck in air. seems to help but who knows. mike- Top
- Top
Please explain to me the issue that the silicone application resolves. I have not heard of this before.Garry Barnes #18531
'67 Lynndale Blue Coupe- National TF, BG
'67 Sunfire Yellow Coupe- 4 Star Bowtie,
- Top
In The old bulbs the seal between the metal socket and the glass can dry out allowing air to get at the filament. The bulb will then fail. There is no assurance the silicone will actually help but it might be worth trying.- Top
Larry- Top
Thanks for the explanation Bob. Makes sense. So, is there anything not correct about the Lectric Limited bulbs for judging? If going to new and correct reproduction bulbs and not have to switch them out after judging, I am thinking that may be the way I should go. Anyone out there have experience with these bulbs and judging? Thanks.Garry Barnes #18531
- Top
Give LL a call and ask them to look at the front of the bulbs for DOT debossing. If there is no DOT on the front of the lens, they should pass muster. Picture of bulbs I bought several years back...passed with flying colors.Leif
Top Flight 2017 Lone Star Regional- Top
In the glass there is a DOT cast in the lens, it's not obtrusive, however it is there and will result in deduction. IIRC facing the bulb it is 1/4-3/8 in from the edge at 10-11 o 'clock
I blew this photo up - I believe this is the location.
_MG_2900.jpgAttached Files- Top
[ATTACH=CONFIG]110036[/ATTACH]
Larry- Top
Larry, those are the ones I am looking for. In looking closely at the LL product, I can see the DOT on front at about 10 o'clock. There are also GM Restoration brand bulbs that I can't see the DOT but have written one of the vendors if there is a DOT on the front of the bulb. Could these be the ones you and Leif have?Garry Barnes #18531
- Top
As Larry stated, I bought my T3 from Zip, as well. They still carry them. I would call them and ask them about the DOT marking on the front glass. Their description says they are DOT approved but I don't see the DOT in their picture. If you zoom in on my picture in post #11, you can see there is no DOT on the lens...anywhere.
Purchase 1960-1967 Corvette T3 Headlight Bulb Set at Zip Products - complete your C1 & C2 Corvette restoration with correct T3 headlamp bulbs.
Leif
