Question On C2(66) Convertible Door Glass R&R - NCRS Discussion Boards
  • Larry E.
    • 1697
    When one wants to just change out door glass for coding(LOF) reasons only does the Ventilator Assembly
    have to be removed out of the car? Looking at the Service Manual it indicates to remove it. When
    I looked at all the Figures/Instructions given is seems to me on a Convertible when the sash retaining nuts are removed
    the Glass should be able to be pulled out. What am I missing here? Has anybody removed the Glass W/O
    removing the Ventilator Assembly out of the Car? Thanks in Advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Gary B.
    • February 1, 1997
    • 7068
    Re: Question On C2(66) Convertible Door Glass R&R
    Larry,
    I can confirm for a ‘66 coupe that the vent window does not need to be removed in order to remove the main side glass. Unfortunately, I have no experience with convertibles.
    Gary
    • Larry E.
      • 1697
      Gary>Thanks for the response; but I want to make sure we are on the same"Page". I did not ask if the Vent Glass had to be
      removed but the the Ventilator Assembly(which contains the vent glass) had to be removed. That is the long frame type
      assembly which in the figure shows the guy twisting it pulling it out from the top. I can see where it might have to be removed
      on a Coupe but can't see why it needs to be removed on a Convertible. Comments Please>Larry
      Larry
      • Gary B.
        • February 1, 1997
        • 7068
        Sorry, yes, I meant the entire vent frame does not need to be removed.
        Gary
        • Larry E.
          • 1697
          Thanks Gary for the info. Just wondering why the Service Manual instructs us to take the
          Ventilator Assembly out for both the Coupe and Convertible. Any other thoughts on this?? Larry
          Larry
          • Gary B.
            • February 1, 1997
            • 7068
            I have no idea. I just know that most people have learned there is no need to follow the Service Manual.
            Gary
