1967 Alternator 55 AMP vs 37 AMP - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1283
    Hello,
    If I use a 55 amp alternator in my 67 small block non-a/c versus the 37 amp it came with, will I create any problems? Or, should I buy a new 40 amp and just change the internals and put those in the 37 amp, correct casing?
    Jerry
  • Jim L.
    • September 30, 1979
    • 1808
    Re: 1967 Alternator 55 AMP vs 37 AMP
    The current sourced by the alternator won't be any greater than the sum of the loads placed on it. So if you aren't adding any additional electrical accessories and if the only change you are making is the alternator, no you aren't creating any problems.
    • Tom E.
      • June 1, 2019
      • 448
      • Gerald C.
        • June 30, 1987
        • 1283
        Thanks for the feedback
          • 15679
          I think all you need to do to increase a 37 amp rating to 55 is swap in the 55 amp stator. The only thing I'm not sure about is if the wire on the output stud is sufficient to support the full load.
            • 43222
            Originally posted by Gerald Coia (11656)
            Hello,
            Jerry
            Jerry------
            No problem, at all, will be created. In fact, if you were to install a 61 amp alternator no problem would be created.
            • Gerard F.
              • June 30, 2004
              • 3806
              Jerry,
              Take a look here:
              https://www.forums.ncrs.org/showthre...ght=alternator
              I restored my original 67 alternator with the innards of a replacement 61 amp.
              I had to do it when I went to a Vintage Air system on my non AC 67.
              It still works great.
              Jerry Fuccillo
