1967 hood alignment--front corner sticks up - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    The right front corner of the hood is up ~ 3/16 of an inch and currently I don't have any shims. How does one bring the corner down so it is flush? The left front corner is perfect.
  • Michael B.
    • February 1, 1985
    • 76
    • James G.
      • August 22, 2018
      • 818
      Re: 1967 hood alignment--front corner sticks up
      If you don't have shims in then Michael has the right thoughts on the hood with out filing or grinding away some fiberglass where the hinge mounts. Allowing the rear of the hood to come up slightly will slightly lower the front - you will probably have to split the difference.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Frank D.
        • December 27, 2007
        • 2703
        These things are always a compromise; I've even heard of people cutting the hinge, grinding it down and welding it back together..
        But its well worth trying an adjustment first.
        Raising the rear a tad should make the front edge dip down BUT if its too high at the pivot point of the hinge that height is fixed and that's a different matter.
        • Domenic T.
          • January 29, 2010
          • 2452
          If it was good once, then hinge location will help.
          Dom
          • Mark E.
            • April 1, 1993
            • 4610
            Tey adding a shim to the rear half of the hinge to lower the front of the hood.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Scott P.
              • April 30, 1992
              • 178
              Marks fix applies to doors too & should fix the hood. When did the hood corner become higher than the surround and maybe why.
              • Michael B.
                • February 1, 1985
                • 76
