1968 Voltage Regulator Attaching Hardware - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 213
    I have an April '68 Corvette and want to ask owners what is their voltage regulator attaching hardware? I have one stud in lower front that was affixed into the fiberglass....think it might have a 3/8 head (missing) and stud looks original. The other hardware installed ended up being 10mm bolt/nut so I know that's not correct. I do not think the reproduction rubber wellnuts and bolts are correct but that is what the supply houses carry. And, I did not see anything in my version of the judging manual. Thanks for your help.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 1968 Voltage Regulator Attaching Hardware
    Originally posted by William Hyndman (45161)
    I have an April '68 Corvette and want to ask owners what is their voltage regulator attaching hardware? I have one stud in lower front that was affixed into the fiberglass....think it might have a 3/8 head (missing) and stud looks original. The other hardware installed ended up being 10mm bolt/nut so I know that's not correct. I do not think the reproduction rubber well nuts and bolts are correct but that is what the supply houses carry. And, I did not see anything in my version of the judging manual. Thanks for your help.
    Some C3 guys will chime in, for sure, but I know in '67 the rubber well nuts were used and, I believe, they were used through the '68 model year.
    Leif
    • Gary B.
      • July 31, 1979
      • 926
      Indented hex head bolt with flanged washer. See attached picture, not the best, but...
      Gb
      • Leif A.
        • August 31, 1997
        • 3654
        Gb
        [ATTACH=CONFIG]109940[/ATTACH]
        Gary,
        It appears, in your picture, that there are rubber well nuts in the fender that the hex head bolts are threaded into. Yes??
        Leif
        • William H.
          • January 1, 2006
          • 213
          My 68 has 2 holes for the well nuts but there is one stud on the lower front which looks original and integrated in the fiberglass. Thanks for the help so far.
          Bill Hyndman
          • Gary B.
            • July 31, 1979
            • 926
            Short answer is yes. It looks like a #10-24 thread. A few pictures. Inside the fender shows the tab that holds the stud and the two rubber well-nuts. Other picture show's the nut on engine compartment side.
            Gary B
