The frequently recommended Melling 10553 oil pump for SB Chevy is not available at Summit or JEGS. I’m not sure if that’s permanent or not. But both vendors now sell the Melling 10553ST, where the ST stands for shark tooth, which describes a new gear design which Melling claims increases volume by 10% to 25%. Regardless of those claims, the 10553ST pump is described as a high pressure pump. The description of the old 10553 pump on the Melling website says “To change pump to lower pressure … install the supplied yellow spring.” The 10553ST description on the JEGS and the Summit websites make no mention of being able to convert the 10553ST to a standard pressure pump via a spring replacement. Has anyone recently purchased the new Melling 10553ST oil pump who knows whether it can be converted to a standard pressure pump?
I know one option is to buy a Melling M-55 standard pressure/standard volume pump, but that seems like a big step down in quality, based on the fact it costs less than 1/3 of what the 10553 used to sell for and what the 10553ST currently sells for.
Finally, GM oil pump # 93427692 does’t seem to be an option since that pump has M55 embossed on it, which suggests it’s the Melling M55 pump, but at triple the cost of the Melling item.
Gary
Gary
