'96 Headlight motors running randomly - NCRS Discussion Boards
  • Paul B.
    • May 31, 1988
    • 43
    All of sudden both headlight motors start running out of the clear blue, no switch activation or anything. And, when i do activate the headlights, they continue to run for about 5 seconds after the lights are in full up position. Any ideas? Relay, motors, or headlight control module? Thanks in advance for help!
  • Keith B.
    • September 15, 2014
    • 1583
    Re: '96 Headlight motors running randomly
    Time to rebuild with new gears and pucks. Many rebuilding articles on the web on how to do
    • Paul B.
      • May 31, 1988
      • 43
      Thanks, but this morning i hit a bump and the motors went off, so i'm thinking this may an electrical issue. Car has only 39k on it.
      • Pat M.
        • April 1, 2006
        • 1575
        Paul, if the gears are all or part of the problem, there's a good article in The Restorer about replacing them, Volume 43, Number 2, Fall 2016. Good luck.
        • Paul B.
          • May 31, 1988
          • 43
          How do i access article? Thanks
          • Pat M.
            • April 1, 2006
            • 1575
            In the past, Vinnie Peters, Restorer editor, has been kind enough to provide links to past articles. His contact information is on page 2 of the Restorer under "NCRS Officers".
