Frosting early 63 wheel covers - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    What is the correct paint to use to create the frosted look? I don't have any frost left on mine to match.
    • 6942
    Re: Frosting early 63 wheel covers
    Troy, if you can find a dull silver, that’s about the color you would want, The silver around the 63 gauges is would you want to look for. Seymour paints on Amazon sell dull silver, it’s a great match.
    • Troy P.
      • February 1, 1989
      • 1284
        • 6942
        • Troy P.
          • February 1, 1989
          • 1284
          Since they are rare maybe judges don't exactly know what the frosting should look like and anything close counts?
          I don't understand the "thinner radius" applicable to early wheel covers mentioned in the TIMJG. The E. 21.2 photo referred to certainly doesn't tell that story.
          So I wonder if I have early wheel covers and a previous owner removed the frosting like I initially assumed? Or do I have incorrect later wheel covers for my #1948 car? If I have the wrong wheel covers maybe no point in trying to paint them.
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 873
            Troy, All of the frosted hub caps I have seen were of the "Thick edge" style. The "Thin edge" style are always fully polished, but I have seen fully polished with the "Thick edge". There could be an overlap period where they had the thick edge but still fully polished them.
            I have not seen "Every" hubcap ever made so there may be exceptions to the rule. There always seems to be!!
            • Jim L.
              • September 30, 1979
              • 1808
              I'd be grateful to anyone who could post comparative pictures of thick edge and thin edge '63 wheel covers. My '63 has been in the family for over half a century yet I don't know what these terms mean. Thanks in advance.
              • Troy P.
                • February 1, 1989
                • 1284
                My car should have the early thick edge. But since mine aren't frosted they may have been switched out at some point. I've just been assuming someone removed the frosting. Maybe there is more to it. So before I go to the trouble to frost them I would like to determine if they are early wheel covers like they should be. Thus like Jim I'd like to see the thickness difference.
                I spent the day testing quite a few paints and searching the city for Krylon Dull Aluminum. No luck there. But I did find a flat nickle paint that has the darker look that I'm seeing in photos of original covers. Thus I wonder if Dull Aluminum might be too silver and nickle is actually a better match. Nickle paint is not that common and perhaps Dull Aluminum was chosen as the best available at the time?
                • Michael V.
                  • May 31, 1995
                  • 77
                  I will try to post a picture. Thin ridge is on the left, thick ridge is on the right.
                  Mike
                  • Michael V.
                    • May 31, 1995
                    • 77
                    Two more detailed pictures regarding the difference between thick (top picture) and thin (bottom picture) lip 1963 Corvette hubcaps. Hope this helps.
                    • Joseph S.
                      • March 1, 1985
                      • 873
                      Mike, Great photos!!
                      • Jim L.
                        • 1808
                        I agree! They clear up the distinction between the two types of covers nicely. Thanks for posting them.
                        • Troy P.
                          • February 1, 1989
                          • 1284
                          Boy am I glad you went to the trouble to post those photos. I thought the difference being discussed was in the width of the rim visible once installed. Turns out it is the depth.
                          The good news is I do have the correct covers. So now I'm back in the mode of having to frost them...which looks to be a royal pain. I have Krylon Dull Aluminum paint on order. That is a paint suggested in an archived post.
                          I'm assuming you can't paint directly onto polished stainless and need something like a self etching primer as a base coat. Any thoughts on that?
                          • Joseph S.
                            • March 1, 1985
                            • 873
                            Troy, The factory paint was directly over the stainless. Scuff them up a bit, make sure they are very clean and spray!
                            • Troy P.
                              • February 1, 1989
                              • 1284
                              BTW just read an old post about frosting 64 wheel covers that is very interesting. One approach that was used successfully was to bead blast the covers to provide the frosted look. Passed judging. I may do that as I have a blast cabinet and it looks easier than priming and painting.
                              Also while I was searching every store in town for Dull Aluminum I found quite a variety of paints that just provide frost and no color. Seems to me those paints could provide the desired results. If I had a spare wheel cover I'd definitely experiment with those.
