Back to 1953 or earlier the battery date code convention was "year-month-plant". The 63-64 model year NCRS TIMJG says that convention was still used up through 64. I assume that was well researched and correct.
I have owned or seen NOS Delco batteries built in the 1960's as over the counter replacements for car model years 1953 up to 67 or whenever the DC-12 wet battery with yellow caps was last used. Those have the following date codes:
That does not follow the "year-month-plant" format and I have no idea how to interpret them. So a change was made by Delco. When was it and how is this new code interpreted? Hopefully someone can solve this mystery.
Some of you with NCRS TIMJGs later than the 63-64 model year edition may find this in your books or in later Delco catalogs.
On the surface it appears that the new convention of the three examples I've seen is "month-year-plant". Note two of the date codes shown above have an "X" in the third position and that could be the New Brunswick, NJ plant. But one has "C" in the plant position and there is no plant I know of with a "C" code. The number in the middle position could be a year indicator (9,2,or 7). A big problem comes in trying to assume the first letter indicates the month because there is no "N" month. December is the last month and it is "M". ("I" was not used)
