66 upper control arm hardware finish ? and tie rod clamps - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 321
    Good morning , reading thru the latest judging guide and saw where the end washers and bolts where painted gloss black like the lower control arm but couldn't find any mention of the upper arm hardware did i miss that, also are the tie rod sleeve clamps clocked in a certain position . any info would be great
    Bob Peckham
  • Gary B.
    • February 1, 1997
    • 7068
    Re: 66 upper control arm hardware finish ? and tie rod clamps
    Bob,
    For ‘66, tie rod clamp orientation is described in the AIM on UPC 9, A2.
    By upper A-arm hardware are you referring to the pivot shaft bolts and nuts that secure the A-arm to the frame?
    Gary
    • Robert P.
      • October 19, 2019
      • 321
      Gary , the end washers and bolts that secure the bushing to the upper arms . Thanks for the info on clamps i know i had seen it somewhere but couldn't remember where.
      thanks again Bob
      • Gary B.
        • February 1, 1997
        • 7068
        Bob,
        The end washers, bolts, and bushings were painted black after attached to the A-arm and pivot shaft. And don’t go full gloss with the paint. Based on my observations, most judges expect to see something on the mid to higher end of the semi-gloss range.
        Gary
