63 Holes in LH fender skirt - NCRS Discussion Boards
  • Thomas B.
    • October 11, 2021
    • 299
    Three holes in fender skirt matching layout shown in the AIM for attachment of fuel injection air cleaner. Should those holes be there on a 340 hp '63?
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 63 Holes in LH fender skirt
    Ah..... No
    Look at both fenders and see if the FI badge mounting holes are filled in.
    • Thomas B.
      • October 11, 2021
      • 299
      No filled holes. Holes would be just below the crossed flags emblem. There is some sort of panel reinforcement at that location on both fenders.
      • Harry S.
        • July 31, 2002
        • 5330
        Tom, please read through this thread.
        https://www.forums.ncrs.org/showthre...njection+holes
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 886
          Tom, I have seen these holes opened up in the past while judging 340HP cars. The most recent was at a Northeast judging meet a couple years ago (Pre Covid) and it was a very original unrestored car with a "Born with" 340 hp engine.
          • Thomas B.
            • October 11, 2021
            • 299
            Harry,
            Thanks for the thread. Radiator support does not have the opening for air intake. Can't verify the wire connector for FI unit. Has 6500 rpm tach.
            Just to clarify, my car is a number matching 340hp car. Has AM radio, short mirror, "storage areas" under the seats. Has 3.70 posi rear although the rear axle code would indicate non-posi. Also has a scatter shield bell housing for some reason. The car was frame off restored at some point and color changed. In the 80's or 90's I believe. vin is 09048.
            • Thomas B.
              • October 11, 2021
              • 299
              Joe,
              Good to know. I was also considering the possibility that the skirt was changed at some point due to a crash or something and they install a new or used one from a fuelie. I would add also that the intake manifold part number is correct for a 340 hp but I cannot locate a date code on it. Has the correct type Carter carb but not the original. I suppose it's possible someone tried to change it to a fuelie and it was changed back to carb.
              • Thomas B.
                • October 11, 2021
                • 299
                Joe,
                Do you know if there two different skirts installed at the factory? One with holes for FI cars and one without for non-FI cars? Or were holes installed at factory for FI cars?
                • Alan D.
                  • January 1, 2005
                  • 2046
                  Believe all fenders had dimples where options were to be installed including the FI air cleaner. For example a dimple exists for the ballast resistor on a TI car, ie no hole would exist.
                  • Joseph S.
                    • March 1, 1985
                    • 886
                    Alan is correct. There is only 1 inner fender. locating dimples are included for all options.
                    • Thomas B.
                      • October 11, 2021
                      • 299
                      Makes sense, Thanks for the replies.
                      • John D.
                        • December 1, 1979
                        • 5507
                        I saw a '63 carburetor car at a regional event that had the holes open for the air cleaner.
                        Now with my high paying NCRS job I am not allowed to make any comments at the show to car owners or judges. God forbid. hahaha
                        Anyhow I told the big blond guy with the shorts about this car. His answer I can't repeat entirely but it does like this.
                        John said the car used to be an FI car but the poor car owner made it a carburetor car. It was sooo funny.
                        That was in Marlborough Mass. John D.
                        • Thomas B.
                          • October 11, 2021
                          • 299
                          Finally got in touch with the previous owner of my car. He told me that right after buying the car in '84 he started to convert it to fuel injection. Had the air cleaner installed. Then, thankfully, it seems he changed his mind and went ahead and had it restored with the carbureted engine and kept it until 2021. Open holes are part of the car's history now.
