fiberglass/composite rear spring - NCRS Discussion Boards
  • Mel S.
    • August 31, 1992
    • 264
    I want to replace the rear spring on my 66 convertible 350 motor with a fiberglass/composite one. The question is that I see different spring weighs to pick from - 315#, 340# and 355#. I want a nice "non-choppy" comfortable ride. Any information will be appreciated.
    Mel
  • Gary B.
    • February 1, 1997
    • 7070
    Re: fiberglass/composite rear spring
    Mel,
    Are you aware that the spring rates you quote are MUCH higher that what came on your ‘66 originally, presuming you had the standard, two-stage 9 leaf spring?
    The rwo-stage, 9-leaf spring used from 1964 thru 1974, GM #3850839, has the following spring rates:
    140 lb/in @ design load of 1360 lb
    196 lb/in @ design load of 1965 lb
    So even the lowest fiberglass spring with a rate of 315 lb/in is more than double the initial spring rate of the 9 leaf. I don’t think anyone sells a fiberglass mono leaf spring that comes close to the 140 lb/in rate.
    Gary
    • David H.
      • June 30, 2001
      • 1559
      Originally posted by Mel La Scola (21474)
      I want to replace the rear spring on my 66 convertible 350 motor with a fiberglass/composite one. The question is that I see different spring weighs to pick from - 315#, 340# and 355#. I want a nice "non-choppy" comfortable ride. Any information will be appreciated. Mel
      Mel
      Answer will vary depending on your choice of spring manufacturer (brand). Whose spring do you intend to use?
      Ride quality is a combination of spring and SHOCKS - recommendation from both Manufacturer and users for quality shocks.
      Numerous threads on CF re composite springs and paired shocks.
      My car is a WIP, I have not driven it with new spring/shocks. After review of numerous threads and manufacturer recommendations, I went with a 355# TRW spring with Bilstein Heavy Duty shocks on front and Bilstein Sport shocks on rear. HD front with Sport rear is a common recommendation for ride quality. Bilstein Sport reportedly do a good job of damping rear fiberglass spring. (1980 originally with FE7 suspension)
      Dave
      • Mark E.
        • April 1, 1993
        • 4607
        I installed a 330# composite spring from VBP (who I think is out of business) on my 454 car. The ride is stiff and choppy, and the car sits about 1" too high. Look for a recent thread I started about shocks which discusses this. It's baffling why Corvette vendors represent these stiff springs as "smooth riding".
        So I'll either restore and reinstall the original spring or get a lighter composite spring. Here's a company which offers a 180# spring:
        I don't know anything about this company; Google just found it.
        If you choose composite, ask a lot of questions about ride quality and height.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Mel S.
          • August 31, 1992
          • 264
          Thanks to all. Good information. I will do more research
          Mel
