54 engine stamp pad - NCRS Discussion Boards
54 engine stamp pad
  • Tony R.
    • April 19, 2017
    • 201
    54 engine stamp pad
    I am on a roll with engine related questions today. Here is one more. Was the stamp pad painted? Mine sure does not look to have been. but it wasn't very rusty. But then there was a lot of oil leaking everywhere over the years. If it was not painted, was it the whole pad, all of the way past the distributor/oil pump shaft hole in the block? attached is a photo of mine prior to hot tanking. I believe that all I did was wipe it with a shop rag and some gasoline to clean the grime off.
    Thanks.
  • Chris S.
    • January 1, 2000
    • 1065
    Re: 54 engine stamp pad
    Originally - yes the pad was painted - those whole engine was painted
    For judging - leave the pad bare - I mask mine off - I mask from the octane recess to all the way across the number with some tape
    Pad looks good
    first 5 are gang stamped the next 2 are hand stamped and the F54YG is gang stamped
    Looks good
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Tony R.
      • April 19, 2017
      • 201
      Thanks for the advice!
