54 coolant neck bolts - NCRS Discussion Boards
  • Tony R.
    • April 19, 2017
    • 201
    Please see the photo. The long bolt is a WB1C and I have no reason to think it's not right. However, the short on e on the left is the one that I have more questions about. It has a circular depression in the middle, with an M in the center. There are three 'dots' around the perimeter. Thoughts?
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 coolant neck bolts
    I have seen both
    The WB bolt is original and correct
    Typically M bolts are side motor mount to block bolts but it is an original bolt
    Use it there - looks great
    As long as the bolts "look" typical there is no point deduct - when you get into hardware store bolts then there is....
    Use it !
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Tony R.
      • April 19, 2017
      • 201
      Thanks much!!
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 928
        I agree with Chris! All looks good. I would put those bolts right back as they were!
