67 Ignition/Door Key - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    I have a 67 that has it's original ignition cylinder and both door looks. Unfortunately, the owner lost the "A" key. All three parts are code stamped 6W51. Is there a source who can make two replacement 6W51 code stamped Briggs & Stratton "A" keys? I was heartbroken to hear Pete Lindahl had passed away. I know this was one of his specialities. I can't afford Jesser's
  • Leif A.
    • August 31, 1997
    • 3627
    Re: 67 Ignition/Door Key
    Dereck,
    Read your post...it is unintelligible. If you're asking about the glovebox/spare tire lock key, you can buy the key blanks online. Any good locksmith should be able to cut the keys to fit the glovebox and spare tire lock. If those two parts aren't the same lock, the locksmith can fix that for you, as well. I would bring both the blank keys and the locks to him so that he can key them the same.
    Leif
    • Gary B.
      • February 1, 1997
      • 7018
      Dereck,
      Do you want code-stamped keys for judging? Or do you just want a set of functional, A-keyway keys?
      Gary
      • Dereck S.
        • July 30, 2008
        • 244
        Hi Gary
        I need code stamped keys for judging.
        • Gary B.
          • February 1, 1997
          • 7018
          sswalker427@comcast.net
          Tell Steve I sent you.
          Gary
          • Dereck S.
            • July 30, 2008
            • 244
            Gary
            I appreciate the help. I'll reach out to Steve.
            Dereck
