1965 s-tube finish - NCRS Discussion Boards
1965 s-tube finish
  • Bruce W.
    • June 30, 1997
    • 360
    1965 s-tube finish
    Hey Guys,
    Recently had my 65 fuel car judged. Was told my s-tube was to shiny. Judging manual just says it has less shine that the air cleaner. but no more info. Is it suppose to be flat or semi gloss.? I understand that the S-tube and the air cleaner hosing were painted at two different locations explaining the difference in finish. Appreciate you help.
    Bruce
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: 1965 s-tube finish
    Your car was probably judged by someone who knows nothing about paint and the way it was originally applied. I can take the same paint and make many different finish appearances based on application method. Just ask John Ballard as he and I spent our working careers in the paint industry.
    • Hank D.
      • January 1, 1999
      • 137
      You may find the information in this thread helpful: https://www.forums.ncrs.org/showthre...-Cleaner-Color
      • Bruce W.
        • June 30, 1997
        • 360
        Jimmy, i will give John a call
        thanks Bruce
        • Michael G.
          • November 12, 2008
          • 2158
          Mike
          1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
          1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
          • Dave S.
            • August 31, 1992
            • 2930
            Originally posted by Bruce Wilcox (29338)
            Hey Guys,
            Bruce
            Bruce,
            Mine has a semi gloss finish. Definitely less shine than the Air Cleaner body. When it was judged at two different Nationals it got positive comments.
            Original cars that I have seen seem to be the same.
            • Bruce W.
              • June 30, 1997
              • 360
              thanks for all your help!!
              Bruce
              • John D.
                • December 1, 1979
                • 5507
                Long ago Michael Hanson made a post on this subject. He posted a photo that I have buried around here showing the radiator core support coming down the assembly line with the S tube with it. Both were painted the same shade of black.
                Just like Dave Strickland's nice photo.
                Mike if you are looking in please email me that photo. Thanks, JD
                • Michael G.
                  • November 12, 2008
                  • 2158
                  John, the attached quote is something Michael Hanson posted on the subject. What’s notable is that earlier he explained that parts dipped “semi-gloss” black (like the s-tube) would be much more shiny than those sprayed semi-gloss. Sounds like the the air cleaner main body (“can”) was always full gloss, and the s-tube could vary between very shiny and a bit duller, depending on the dip process.
                  Mike
