TI box 1965 - NCRS Discussion Boards
TI box 1965
  • Bruce W.
    • June 30, 1997
    • 358
    TI box 1965
    Hey guys, need a little help with a TI box. car just stop running and would not start. does anyone have trouble tree. I need to know how to test the box. voltage or ohms for each wire. thanks for your help
    Bruce
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: TI box 1965
    Bruce, Are you sure it's Ignition?
    Is your TI box original Delco circuit board? Or upgraded to the newer type module? (M&H or K&B). Remember that if it's the original Delco type only pull 1 plug wire to test spark.
    There is a Service doc in the above Sticky which may help diagnose.....(64-65 same)
    There is a diagnostic flowchart on page 5.
    There are many things that could cause a no spark(if you're convinced that is the issue). Ensure you get 12V at the Pink/Blk going into the TI harness with Ign on. If good.....
    Other TI Common issues :
    - Poor connections at the 3 prong plug to the box. Sometimes the internal terminals in the harness plug can move causing a fault.
    - Open grounds. The '65 mounts the box to the core support. Make sure the grounds are clean and tight.
    - The distributor Pickup Coil 2 prong harness at the distributor is another common failure. The wires going into the distributor can become brittle and break. A ohms test of the PU coil(unplugged) should read in the ~500 to ~700 ohm range. Best to use clips on your meter then wiggle the wires to ensure solid contact with no intermittent readings, however it'll fluctuate a small amount.
    - Ensure you're getting full Bat+ during crank at the Pink/Blk. This comes from a separate wire from Starter Solenoid R terminal. This maintains proper voltage at the TI box and PU Coil during crank. (nothing to do with Ign Coil+)
    - Ensure you're battery is at full capacity. Low cranking voltage can prevent TI operation.
    Rich
    • Bruce W.
      • June 30, 1997
      • 358
      Re: TI box 1965
      Richard, thank you. Good info
      Bruce
      • David B.
        • March 1, 1980
        • 689
        Re: TI box 1965
        Delco-Remy service bulletin 1D-155 (dated 7-1-65) If you can pull off internet should also help.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11323
          Re: TI box 1965
          David, I found it here...
          If Bruce's TI box has the original circuit board, yes this is a good aid. If he has the upgraded circuit board some info won't apply as the circuit components are different.
          However, basic tests would apply.
          Rich
          • Robert K.
            • June 30, 2001
            • 212
            Re: TI box 1965
            Dave,
            Here's another troubleshooting article from Chevrolet (tispecialty.com website) for 64-65's........ Open to view or, just go to the website noted and find the article........
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              Re: TI box 1965
              Originally posted by Robert Kerestes (36438)
              Dave,
              [ATTACH=CONFIG]109358[/ATTACH]
              Yes that's on pg 5 of the link I posted earlier, but a good page to easily print out.
              Note that the '66-'71 flow chart is different as the coil is wired differently. Attached below for reference.
              • Bruce W.
                • June 30, 1997
                • 358
                Re: TI box 1965
                Rich, thanks for the input. This TI box was replaced 2 years ago with a new one from M and H. Does this change the testing procedure?
                Bruce
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  Re: TI box 1965
                  Bruce
                  Bruce, Not positive about the M&H but I think most of the voltages in the flowchart should be the same.
                  The circuit components are very different so anything related to testing transistors and internal devices will not apply.
                  Just remember you need a fully charged battery and good grounds for accurate tests.
                  The distributor PU Coil doesn't care which module is there so that test result should always be in the 500-700 ohm range with it disconnected from the plug.
                  Rich
                  • Bruce W.
                    • June 30, 1997
                    • 358
                    Re: TI box 1965
                    Rich, Thanks for your help. It was the TI box which BTW was replaced a couple of years ago with an M&H box. Seems strange it could go bad that soon?
                    Bruce
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11323
                      Re: TI box 1965
                      Bruce how did you determine it was the M&H module? Did you have another one to replace it?
                      Rich
                      • Bruce W.
                        • June 30, 1997
                        • 358
                        Re: TI box 1965
                        Rich, I know it was an M&H because the former owner told me he replaced the box about a year before I bought the car. I did not have another one. I borrowed one from a friend and the car fired right up!! I ordered a new box from Zip products. It is a Delco. A big question here is what causes a box to go bad??
                        Bruce
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11323
                          Re: TI box 1965
                          Bruce glad you got it diagnosed. Good you were able to borrow one.
                          Why it failed? Electronics fails some times.
                          BTW, If you got the Zip complete module(box and circuit board), yes it's a Delco on the outside, but it includes the K&B circuit board inside, which IMO is a better product. FYI, you could have ordered just the K&B circuit board and swapped it out also.
                          Rich
