ignition switch connector - NCRS Discussion Boards
  • John B.
    • April 20, 2021
    • 111
    Hello all,
    i got a new M&H dash wire harness. The ignition switch connector is black and does not align correct with my ignition switch. My original connector is clear/opaque, but is broke. I called lectric limited, M&H and they do not have the original style. Does anyone have any ideas where to get one?
    Mike
  • Scott P.
    • April 30, 1992
    • 178
    Re: ignition switch connector
    Mike, Is it for a 66. If so I can send you one. Of course it will be used. How about a picture of the plug in end from you of the old one. Scott Fogaley@sbcglobal.net
    • Frank D.
      • December 27, 2007
      • 2703
      I can understand maybe a color difference, but the repro connector won't even plug in ?
      Never heard that about Lectric Limited or M&H harnesses..
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11325
        John, Is it possible your switch isn't a '66 switch. Different years used different plug configurations.
        Rich
        • John B.
          • April 20, 2021
          • 111
          Rich,
          From what i can tell it is correct. Its a 673 switch. Is this correct?
          • John B.
            • April 20, 2021
            • 111
            Thanks Scott, I will post a picture soon.
            • John B.
              • April 20, 2021
              • 111
              Frank, i can plug the connector in but the 3 anti theft prongs do not line up.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11325
                Originally posted by John Bennett (67943)
                Rich,
                I think the 66 uses a 686 but I could be mistaken. What does the AIM state?
                • Gary B.
                  • February 1, 1997
                  • 7038
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11325
                    Ok Thanks, Was on the road and just got back and the AIM says so too.
                    Pictures would help.
                    Rich
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11325
                      Edit ( I had them reversed. Repro was the opaque, original was black)
                      For reference here's the back of a 67(686) switch showing the plug. They may have given you a 66 harness with a 67 plug.
                      This was on the original harness(tabs broken).
                      • John B.
                        • April 20, 2021
                        • 111
                        Here are a few pictures. One compares my original clear and the black one that came with the new harness.
                        • John B.
                          • April 20, 2021
                          • 111
                          AIM says 673.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11325
                            John that looks like the 67 plug. Best to contact the supplier as it appears wrong.
                            Rich
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11325
                              When you contact them you can send them this photo. I did a crop of your repro and a 67 plug I had in the shop.
                              More reference photos of a 67 plug. Note the lock tabs were broken off on this one. .... Rich
                              1206211403_resized.jpg 1206211406_Burst01_resized.jpg 1206211407_resized.jpg 1206211408_resized - Copy.jpg
