Powerglide transmission relay for 1959 - NCRS Discussion Boards
  • Gerald A.
    • April 30, 1997
    • 45
    I have a 1959 Corvette low horse fuel injection. I cannot find the wiring diagram for the transmission relay that mounts to the firewall. Have the wiring diagram and AIM manual, no mention of the relay or wiring. It is mentioned on the judging sheets, any help would be appreciated
  • Don H.
    Moderator
    • June 16, 2009
    • 2257
    Re: Powerglide transmission relay for 1959
    Neutral Safety Relay Switch. Mounts down low on the firewall or footboard, above the starter?
    • Joe M.
      • April 30, 1990
      • 1338
      The 1960 AIM shows the wiring (RPO 313, Sht. 3.00)and I believe it is the same. Yellow wire to solenoid and violet wire goes to ignition. Both wires are wrapped in the ammeter-starter harness assembly.
