1967 Nov 66 build date, need installation experience instructions, New Headlight Dash switch that also dims the Dash and Dome Lights. Thank you
New Headlight switch Installation
Re: New Headlight switch Installation
Pull carpet away from the dimmer switch, remove two screws holding switch to floor, disconnect electrical connector. Reverse procedure to install.
About a 15 minute job.Leif
Top Flight 2017 Lone Star Regional- Top
Sorry did not give you enough info, this is the dash Headlight switch that also dims the dash and dome lights, Thanks- Top
Your original post asked about the dimmer switch. I assumed, by your verbiage, that you were referring to the floor dimmer switch. With your new post, you can disregard the information I gave you.
To remove the dash headlight switch that turns on your lights, there is a small, spring loaded button on the bottom of the switch behind the dash. Push that button in while pulling on the switch knob to remove the rod and knob. You will then see a special nut holding the switch in place. You can use a pair of needle nose pliers to remove that nut. Push the switch through the dash. Remove the wiring harness. Reinstall is a reverse process.Leif
