Oil filter cannister rebuild kit C1 C2 - NCRS Discussion Boards
  • Tim S.
    • May 31, 1990
    • 706
    I have been looking around for a rebuild kit for a 56-67 oil filter cannister rebuild kit. I've bought them through the years and cannot seem to find one. Am I missing something obvious?
    Tim
  • John F.
    • March 23, 2008
    • 2409
    Re: Oil filter cannister rebuild kit C1 C2
    Long Island Corvette usually has them.
    • Philip A.
      • February 26, 2008
      • 329
      Long Island Corvette Supply Inc The 63-67 Corvette Parts ONLY
      ------------------------------------We are now Closed for business.announcement:After nearly 40 years of manufacturing and providing quality restoration parts for 1963-1967 Corvette enthusiast, Long
      Island Corvette Supply, Inc. of Copiague, NY has sold all available inventory to Zip Products of Mechanicsville, VA.
      The sale is effective August 31, 2021.
      We know this transition will take some time, but you can be certain Zip Products will continue the tradition of
      providing high-quality Corvette parts for the most iconic Stingray Corvettes.
      All inventory will be moved to Zip's Mechanicsville location. Please have patience during the transition.
      >New customer order inquiries
      and wholesale accounts can be directed to:
      Zip Products Zip-Corvette.com
      Email: customerservice@zip-corvette.com
      • John F.
        • March 23, 2008
        • 2409
        Sold out to Zip. My error.
        • Tim S.
          • May 31, 1990
          • 706
          I miss Long Island.......
          • Frank D.
            • December 27, 2007
            • 2703
            Like many things lately I can't seem to find a rebuild kit either - but there isn't much to them, maybe you can recondition the original canister you already have.
            • Danny P.
              • June 30, 2002
              • 341
              Tim
              Tim , what wrong with your oil Cannister
              is it leaking , oil filter cartridge comes with the filter and upper rubber o'ring, the rebuild kit comes with only a lock clip and small rubber washer and a copper washer , the bottom crush copper washer is the one that leaks, 48058743d1485783935-oil-filter-canister-rebuild-kit-oil_canister_kit.jpg i rebuild mine with out a kit i match up the cooper and rubber washer and reuse the steel washer and you can save the clip.
              • Tim S.
                • May 31, 1990
                • 706
                is it leaking , oil filter cartridge comes with the filter and upper rubber o'ring, the rebuild kit comes with only a lock clip and small rubber washer and a copper washer , the bottom crush copper washer is the one that leaks, [ATTACH=CONFIG]109237[/ATTACH] i rebuild mine with out a kit i match up the cooper and rubber washer and reuse the steel washer and you can save the clip.
                Exactly Danny........thanks for posting that!
                Tim
                • Larry M.
                  • January 1, 1992
                  • 2694
                  Tim
                  Tim:
                  If you have access to a lathe, the professional canister rebuilders cut a thin and shallow circular groove in the bolt at the retainer clip location. Then install an "e-clip" or a snap ring to replace the retainer (which is otherwise a hammer it down friction fit on the bolt).
                  Professional cans are powder coated and silkscreened........but you can also use a decal, and then spray finished can with a satin clear coat to keep it looking good for a longer time. You can also just paint black with semi-gloss paint vs powder coat.
                  Larry
                  • Tim S.
                    • May 31, 1990
                    • 706
                    Originally posted by Larry Mulder (20401)
                    Tim:
                    If you have access to a lathe, the professional canister rebuilders cut a thin and shallow circular groove in the bolt at the retainer clip location. Then install an "e-clip" to replace the retainer (which is otherwise a hammer it down friction fit on the bolt).
                    Larry
                    Thanks for sharing Larry! This is on an original car that I just bought so I am just working on the mechanicals and gentle cleaning
                    Tim
                    • Joe M.
                      • April 21, 2020
                      • 37
                      Tim
                      Tim, I got to drop by SOON!
                      • Donald O.
                        • May 31, 1990
                        • 1586
                        I know this is an old thread, but....
                        I am yet to find a vendor that has a canister rebuild kit. Wheres one available? I am missing the rubber washer and its matching metal washer that goes beneath the metal cup.
                        Any suggestions?
                        Don
                        • Shane B.
                          Infrequent User
                          • May 1, 2021
                          • 14
                          Which way does the retainer clip go back on with fins upward or downward?
                          • Kenneth B.
                            • August 31, 1984
                            • 2090
                            Looks like down. See post above for diagram.
                            • Bert L.
                              • April 30, 1977
                              • 427
                              Hi!
                              I want to rebuild my can without a kit and would sincerely appreciate
                              comments/suggestions from anyone who has done so.
                              My concern is how to remove the retainer clip in a manner that
                              won't unduly degrade/compromise it's original retention function.
                              Thank You.
                              Bert Levesque
