65 Turn signal switch - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    Following a body off restoration of my 65 Coupe, I reinstalled the telescopic column. I have stoplights but no turn signals. No dash turn signal lights or front or rear turn signal lights. Have front and rear parking lights. Flasher working. Have power to purple wire on accordion connector male connector. Turn signal switch almost new. I am thinking that it is in the switch at the connection from the flasher? I am considering taking the switch apart inside the column to check this connection for power?
    Dave K.
  • James W.
    • December 1, 1990
    • 2679
    Re: 65 Turn signal switch
    Dave,
    Make sure the wiring connection at the bottom of the steering column is pushed together all the way. Sometimes they don't seat fully and can cause problems like you are describing. That would the first thing I would try.
    James
    • Dave K.
      • November 1, 1999
      • 952
      Originally posted by James West (18379)
      Dave,
      James
      James,
      Tried that first
      DaveK.
