67 BB alternator question - NCRS Discussion Boards
  • Lorne G.
    • June 30, 1988
    • 118
    The alternator on my 67 Big Block with P/S does not have a lock washer behind the assembly nut, is this correct? I thought all alternators used a lock washer.
    Also there is a flat washer spacer between the pulley and alternator fan blade. Is this correct as well?
    I am not familiar with Big Blocks with power steering.
    Thank you.
    Lorne
  • Leif A.
    • August 31, 1997
    • 3651
    Re: 67 BB alternator question
    In the '67 AIM, UPC L36, A3 shows a lock washer installed.
    Leif
    • Lorne G.
      • June 30, 1988
      • 118
      Sorry, perhaps I was not clear about which lock washer. I meant the the lock washer behind the nut holding the pulley on the alternator shaft. My alternator does not have a lock washer behind the pulley nut.
      I also have a flat washer between the pulley and the fan blade which I don't is correct.
      The previous owner changed the pulley and I think he assembled the pulley incorrectly.
      Lorne
        • 43273
        Lorne
        Lorne------
        No washer between the fan blade and pulley. The pulley is retained to the shaft by a "wave" washer, GM #1941978, and a special nut, GM #1915172. The washer is discontinued. The nut remains available.
        When the assembly is mounted and the nut torqued, the washer appears as a flat washer since it is compressed.
        By the way, a washer between the pulley and the fan might be necessary if an incorrect pulley is being used.
        • Lorne G.
          • June 30, 1988
          • 118
          Thanks Joe,
          That is the information I needed. I will check with some of the Corvette aftermarket retailers to see if I can find a wave washer since GM no longer carries them.
          Lorne
          • Joseph A.
            • June 20, 2012
            • 136
            I believe there should be a lock washer behind the nut, I have a 427/400 with P/S and there is a lock washer.
              • 43273
              Joseph------
              There is a lock washer behind the nut. It's the "wave" washer I described above. The "wave" produces a "spring-like" locking action.
              If you're referring to a split lockwasher, I do not believe they were originally used. However, they are the type usually supplied with rebuilt alternators (or, field installed by folks that lost the original washer).
              • Gary B.
                • February 1, 1997
                • 7065
                Lorne,
                NOS GM 1941978 wave washers show up on eBay. Search for them there. Not cheap, but the real deal.
                Gary
