72 LT1 Holley carburetor - NCRS Discussion Boards
  • Fred H.
    • December 4, 2019
    • 318
    The TIM/JD references that OEM the holly carburetor came with dark brown metering bowl gaskets and the OEM cleaner base gasket was tan or brown. The current Holley rebuild kits the bowl gaskets are blue and the cleaner base gasket is black. What are the judging consequences using the current Holley gaskets?
    Fred Hickey
    Care taker of Top Flight 72 LT1 C60 Convertible #26756
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 72 LT1 Holley carburetor
    Coat the edge of the gaskets with a brown flow pen..........
    • Daniel T.
      • July 5, 2019
      • 34
      Corvette central shows a tan/cork type air cleaner base gasket-- https://www.corvettecentral.com/c3-6...-jet-to-152140 - although I'm not sure if it should be cork or paper?
      Mr. Gasket still has the old brown/tan cork gaskets, https://shop.advanceautoparts.com/p/mr.-gasket-fuel-bowl-metering-block-gasket-set-1509/5022363-P?navigationPath=L1*14932%7CL2*14981%7CL3*15272%7C L4*-49996835
      62 Corvette 327/340
      63 Corvette SWC 327/300
      67 Corvette Convertible L79
      2006 Corvette Z06
      2011 Corvette Grand Sport Convertible
      also a couple 68 Camaro's
      • Fred H.
        • December 4, 2019
        • 318
        Daniel, thanks for the information, I believe that's what we're looking for. Our 72 matching #'s LT1 is a convertible with factory ac.
        Fred Hickey
