72 with new brakes - NCRS Discussion Boards
72 with new brakes
  • Bob H.
    • July 31, 2000
    • 827
    72 with new brakes
    Brakes working fine but after car sits a couple of days, the pedal go close to the floor. 2 pumps and its back where it should be. Manual brakes. Any ideas?
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 72 with new brakes
    Bleed them again. Still air in system.......
    • Bob H.
      • July 31, 2000
      • 827
      I will do that but I have a solid pedal and good stopping power
        • 6955
        Bob another thing to note is make sure that your not seeing any fittings that may have a slight leak. Basically anything that was disturbed when you did the brake work. This will let air into system while the car stills.If you replaced metal lines with stainless they have a hard time sealing and sometimes require loosening and retighting a few times, make sure to crank them really tight.
