Exhaust Sleeve - NCRS Discussion Boards
Exhaust Sleeve
  • Paul A.
    • April 21, 2021
    • 227
    Exhaust Sleeve
    Had a slight exhaust leak on the passenger side at the manifold flange union. 66, 427/390 car with side pipes, 2.5 exhausts. When I disassembled, I removed a heat riser that was jury rigged with screws to fill holes from a long removed baffle, flat gasket, donut and extension sleeve. Replaced all with new parts including a new riser filler. As I was under car working on my back anyway I decided to remove drivers side also. Obviously no riser, however, there was only a donut but no extensions sleeve. My question is; Does both sides of exhaust to flange supposed to have the sleeve? Assembly manual shows sleeve only on drivers side.
  • Gary B.
    • February 1, 1997
    • 7076
    • Paul A.
      • April 21, 2021
      • 227
      Re: Exhaust Sleeve
      Thank You Gary, Sleeve ordered today for the drivers side. Be Well.
