1962 turn signal manually cancel - NCRS Discussion Boards
  • E B.
    • March 1, 1978
    • 126
    Works perfect on L&R turns but hard to find center spot manually. Is there a detent for center, mine is just guessing. Thanks Ed
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1962 turn signal manually cancel
    Yes - there is a leaf spring that centers the mechanism...sometimes its missing or needs shimmed;
    here is more info in the first document, this refers to a 60 but a 62 should be the same.
    If you decide to dig into it - the first 3-4 pages in the second document will show you how.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      Yes that flat leaf spring is what centers the mechanism. There are tabs on the back of the rotating ring that keep it centered. Lube the contact points for smoother operation.
      • Dennis C.
        • June 30, 2002
        • 888
        Often, the two pins that the flat spring rest on wear slightly, but sufficiently that the turn signal does not return to center. The fix is small brass sleeve (tubing) to fit over those pins. If all else fails and you can't find the information, I have the dimension needed for the brass sleeves somewhere. I had to make a pair for a car I worked on.
        • Frank D.
          • December 27, 2007
          • 2703
          Yes, I've seen that done as well as using thin metal shims along the leaf spring's length...
          THe goal is to increase the tension the spring applies to the actuator by one means or another.
          • E B.
            • March 1, 1978
            • 126
            Thank you Frank for the answer to my issue with the centering of the switch mechanism....will check it this coming winter while replacing the dash pad. Ed
            • E B.
              • March 1, 1978
              • 126
              Thanks Richard, mine may be the issue.Ed
              • E B.
                • March 1, 1978
                • 126
                Thanks Dennis for all your advice, you guys are what this membership is all about. Ed
                • E B.
                  • March 1, 1978
                  • 126
                  Pulled the steering this morning to find the flat tension spring missing....must have gotten lost over the 40 yr restoration.
                  thanks to all for your help in this simple but trying issue. Ed
