Deductions - Urethane vs Fiberglass Nose & Tail - NCRS Discussion Boards
  • Brian D.
    • April 30, 1999
    • 425
    Trying to determine what point deduction should occur for '73 thru '82
    when the urethane nose has been replaced with a fiberglass piece, or '74 thru '82 tail with fiberglass replacement.
    Standard Deduction Sheet doesn't mention this occurrence under Section 12 (Body Fiberglass/Component Fit)
    or Section 13 (Service Replacement/Repro/Non-OEM).
    I'm leaning toward 20% deduction for over restoration, as these parts typically fit better than original.
    Has anyone encountered this previously?
    B.D.
  • Tom R.
    • June 30, 1993
    • 4104
    Re: Deductions - Urethane vs Fiberglass Nose & Tail
    Brian
    Work with your conditions of originality...date, finish, completeness, configuration and installation with 20% assigned per condition. Fit was never perfect but gross fit may be. Perhaps the best illustration is a 76 where the indentation for the rear emblem is absent!
    What would be the deduct?
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • David H.
      • June 30, 2001
      • 1562
      Brian
      Your SDG #12 20% Over/Under Restoration seems like an appropriate fit. Any possibility a 5% Atypical Color would work (visibility of component)?
      SDG #13 Service Replacement provides C.D.C.I.F. guidance when evaluating replacement parts. As SDG #12 is already specific to your situation (body), I would not use #13 as my deduction reference.
      Dave
      • Brian M.
        • February 1, 1997
        • 1842
        I would think it should be a 50% standard deduct.
        • Tom R.
          • June 30, 1993
          • 4104
          After BM's comment, I had to go back to the Judging Reference Guide and followup on your original assessment and have to agree but conditionally.
          I would say that the 50% applies to, primarily one-piece front ends when fenders are molded into the hood surround. I may be wrong but I think that's the intent of the 50% rule.
          The 20% would apply if detectible. Otherwise, as I indicated above that without some identifiable embossment, it could pass, depending on an individual judgement's assessment.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Mark E.
            • April 1, 1993
            • 4607
            Wouldn't this be a configuration deduction since it's fiberglass? And this would be easily detected. So maximum 20% originality deduction?
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
              • 11695
              That's what I was thinking at first, but you could possibly add configuration (material) and date, since you know it's the wrong material and obviously made long after the car was built.
              • David H.
                • June 30, 2001
                • 1562
                Mark
                Body fiberglass is assessed by Standard Deduction Guideline #12. C.D.C.I.F. Matrix judging does not apply.
                Dave
                • Mark E.
                  • April 1, 1993
                  • 4607
                  Originally posted by David Houlihan (36425)
                  Mark
                  Dave
                  But aren't we judging the urethane bumper, not the fiberglass?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • David H.
                    • June 30, 2001
                    • 1562
                    Mark
                    You are correct. Body fiberglass and component fit are in a separate section from bumpers. SDG #12 would not apply.
                    Dave
